Wifi calling - port requirements
ziqex
Level 4
Level 4
What are the firewall required ports for wifi-calling?
I've found old article that stated: UDP ports 500, 4500, and TCP 143 ports but not sure if there are all ports that need to be allowed
We have restricted internet breakout for the visitors wlan and I wanted to allow certain ports to allow guest to use wifi calling as there is no mobile carrier signal available.
Thank you.
Daniel
Here you go.
UDP 500
UDP 4500
UDP 16384 - 49327 for RTP
Reference
https://support.apple.com/en-ae/HT202944
**** please remember to rate useful posts
8 Replies 8
balaji.bandi
You need  5061 / 443 https for authentication, if you looking any voice mail then  993
BB
I have not found the info about 443
So far I've found the below list listed on the EE support community forum (may be carrier dependant)
udp/500,
udp/4500,
udp/5060-5061,
udp 40283-59999
TCP - 143
Daniel
most provider use 443 for authentication, if the application using different port then its different case.
BB
There is no fixed answer. It depends on the application. Some apps use
STUN, other use SIP default ports and RTP default ports, others use non
standard ports, others use 443, etc.
Find the application datasheet to get these details. Otherwise, go the
hard way of getting wireshark capture or window resource mon to see what
ports are used by the application.
***** please remember to rate useful posts
I want to use Wi-Fi calling in the mobile phone.
Not using external apps but built in feature in android/apple devices.
Thanks.
Daniel
Here you go.
UDP 500
UDP 4500
Reference
Is this RFC standard for all mobile phones including Android phones?
I don't have anything specific but since it's RFC I highly expect that it's
same for andriod.
