Unable to delete a Device Pool
Kamil G
I'm inable to delete a "Device Pool" (CUCM 6.1.3.2000-1).  I get a message that there is a pkid in use somewhere and it can't be deleted.
"Error occurred. One or more record did not get deleted. The pkid column in the devicepool table in the database is being referenced from another table. Please check the dependency records and remove the reference and the try the delete again."
Any ideas???
2 Accepted Solutions
Aaron Harrison
First go into Enterprise Parameters under the System menu, and enable 'Dependency Records'.
Then go back to the device pool, and on the 'related links' drop down do a dependency search. This will list all the things that reference that device pool; once they are all put in a different DP or deleted, you can delete the device pool.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Yep, no problem.
Only thing to be aware of is that dependency record searches can use up some process time; that's why they default to disabled.
If you have followed best practice and have your publisher not running any phones normally (i.e. they're all registered to the subscriber) then you'll have no problems at all. I always have it enabled...
Aaron
Please rate helpful posts and mark answered questions that you've got a satisfactory response from to help identify useful content in the forums...
https://supportforums.cisco.com/docs/DOC-6212
Aaron Harrison
Aaron
Cool.... thanks.... can we enable "Dependancy Records" during working hours
Yep, no problem.
Aaron
Thank you.... I found some "Phone Templates" were still using the device pool.... I delted these templates... then I deleted the device pool.  It worked... thanks again.
