Hi,I have a lot of messages in sdi traces like:07/07/2010 16:12:33.398 CCM|DbMobility: can't find remdest 990567189313 in map|<CLID::StandAloneCluster><MASK::ffffff>990567189313 - incomming number.Does anyone know why this message can appear?
HiI need integrate Cisco unified Communications Manager 7.0 with MOC R2 2007 (Microsodf Office Comunicator)somebody know about this integration?Thanks a lotMarco
I have a non gatekeeper controlled inter cluster trunk configured between 2 clusters A and B.Cluster A i have Publisher and Subscriber , and in cluster B i have publisher only.ICT Configuration : Cluster A ...
HiIs it possible to create a SIP Trunk ( Not ICT) between 2 Call manager servers present in 2 different networks with routing enabled between them. If Yes,could someone help with its configuration.Thanks in AdvanceAbraham
can a Cisco IP phone 7937G be configured to work sith SIP protocol? Thanks
Hello,I have a problem with CP-7962G and CP-7915 expansion module; expansion module CP-7915 does not work!I have Cisco Unified CM version 6.1.1.2112-1 so, I must have 1.0(4) - SCCP firmware version like the following table, but CP-7915 does not work...
We have ran many months problem free on our Cisco CommunicationsManager server until last night. I came in this morning and all of our 7940 model and 7960 model phones in our headquarters office say 'Registering IP'. However all of the 7905 and 794...
I am about to upgrade our CUCM from version 7.1 to 8.0(2c). We are runninng CUPS 7.0.6. Are there any issues with leaving CUPS on the 7 code, while upgrading the CUCM cluster to 8.0?
Hi,I was wondering whether i can implement the below feature in CCM 7.1Requirement: I want to restrict some users so that they can'y make more than 100 (100 is an imaginary value, it can be of any numbers) calls per day. Kindly suggest.Rgds,Partha
folksI need help understanding the upgrade procedure i need to follow from CCM 4.x to CUCM 7.xCurrently i have 2 distinct clusters one running CCM 4.x and the other running CUCM 7.xI want to decommission the older verison of the CCM and move all the ...
Hello, I'm trying to upgrade the firmware of a 7975g ip phone with cucm 6.1.2, I already install the firmware in the server i see it in menu Show--->Software of OS Administration: cmterm-7975-sccp.8-5-3.cop ---------------> Active when I ...
I can not get our Cisco CER to see a Cisco WS-C2960-24PC-L Switch. It's has flash:c2960-lanbase-mz.122-44.SE3/c2960-lanbase-mz.122-44.SE3.bin" It works fine with the 3560 switch.CER System Version: 2.0.3.1000-7 ...
Hi,I have used 7940 with Non-Cisco callmanager but now iam in need of configuring 7941g for Non cisco call manager.In Admin guide its mentioned that line settings in phone can be configured using cisco call manager and Proxy address cannot be modifie...
Hi AllPlease can you help I am getting this error on my 2801 router "%CONTROLLER-2-FIRMWARE: Controller T1 0/3/1, firmware is not running" and that VWIC-2MFT-T1 wont ever come up because I always get those error messages I think . I have configured...
HiI have a cordless phone connected to PABX and PABX connected a voice gateway. As the cordless phone press the digits then press the 'Call' to send out number, one of the digit has been lost as below. The 8 of 8453 will be lost.68453 ---> Call 6 ac...
Subject | Author | Posted |
04-26-2025 05:48 AM | ||
04-24-2025 02:49 PM | ||
04-15-2025 02:12 PM | ||
04-15-2025 10:57 AM | ||
04-15-2025 03:40 AM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
