01-20-2012 03:56 AM - edited 03-16-2019 09:07 AM
Hi All,
We have Using CCM 4.0 .All the Call from out side will Come to the Reception IP Phone (Model 7940). From there We are unable to forward the call to my mobile. From Extenson we are able to forward the Call to mobile
Roopesh
Solved! Go to Solution.
01-24-2012 08:07 AM
Hi Roopesh,
From your config the components for ISDN/PRI 2/1:15
controller E1 2/1
framing NO-CRC4
clock source internal
pri-group timeslots 1-31
description for Income
interface Serial2/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
voice-port 2/1:15
connection plar 500
dial-peer voice 106 voip
destination-pattern 5..
session target ipv4:10.10.14.11
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
I would change/add a couple items
controller E1 2/1
framing NO-CRC4
no clock source internal
The ISDN/PRI should be taking it clock from line not internally
I would also add a dial peer to match incoming calls from this PRI
dial-peer voice 2 pots
description *** FOR INCOMING DIAL PEER MATCHING ***
incoming called-number .
direct-inward-dial
port 2/1:15
Please nort that this line
(incoming called-number .)
Needs to include the "space" and the fullstop "."
Can you also confirm that the ISDN is in service and Up
show isdn status
Alex
01-25-2012 02:21 AM
Roopesh,
Glad to be of assistance.
Good to hear of success
Please rate useful posts
01-20-2012 06:03 AM
Depending on you SP this may be that the forwarded call is being sent to the mobile with a "Calling Number" that is not supported by you SP.
Can you share any traces/debugs
on the gateway --- debug isdn q931
Or at least more info re your network connectivity ISDN/FXO SIP trunk etc.
etc.
Alex
01-20-2012 06:51 AM
Hi Alex,
Thanks for the Replay
Please find the Result of Debug
oh-rt2#debug isdn q931
debug isdn q931 isON.
*Mar 7 22:04:13: %PS-3-MULTFAIL: There is more than one failure with the Power System 1; please resolve problems immediately
*Mar 7 22:04:17: ISDN Se4/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0728
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0181, '125'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x80, '8970325670'
Plan:Unknown, Type:Unknown
*Mar 7 22:04:17: ISDN Se4/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8728
*Mar 7 22:04:18: ISDN Se4/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8728
*Mar 7 22:04:24: ISDN Se4/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8728
Progress Ind i = 0x8488 - In-band info or appropriate now available
*Mar 7 22:04:35: ISDN Se4/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x8728
Date/Time i = 0x0B0A0C1419
*Mar 7 22:04:35: %ISDN-6-CONNECT: Interface Serial4/0:30 is now connected to 8970325670 N/A
*Mar 7 22:04:35: ISDN Se4/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0728
*Mar 7 22:04:43: %PS-3-MULTFAIL: There is more than one failure with the Power System 1; please resolve problems immediately
*Mar 7 22:05:13: %PS-3-MULTFAIL: There is more than one failure with the Power System 1; please resolve problems immediately
*Mar 7 22:05:33: %ISDN-6-DISCONNECT: Interface Serial4/0:30 disconnected from 8970325670 , call lasted 57 seconds
*Mar 7 22:05:33: ISDN Se4/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0728
Cause i = 0x8090 - Normal call clearing
*Mar 7 22:05:33: ISDN Se4/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8728
*Mar 7 22:05:33: ISDN Se4/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0728
*Mar 7 22:05:43: %PS-3-MULTFAIL: There is more than one failure with the Power System 1; please resolve problems immediately
% Type "show ?" for a list of subcommands
oh-rt2#sh debug isdn q931
*Mar 7 22:06:13: %PS-3-MULTFAIL: There is more than one failure with the Power System 1; please resolve problems immediatelyterm mon en
oh-rt2#ensh debug isdn q931term mon en term mondebug isdn q931sh en ensh debugging
The following ISDN debugs are enabled on all DSLs:
debug isdn error isON.
Roopesh
01-20-2012 07:01 AM
This call looked like a good call taht was set up outbound and cleared by the gateway
and lasted 1 minute 16 secs
Alex
01-20-2012 07:40 AM
HI
01-20-2012 08:38 AM
As you can not supply a trace at this time there are a couple of things you can
check.
1) CUCM Admin
Service ---> Service Parameters
PUB ADDRESS Service Call Manager
Advanced
Then look for the parameter
Block Offnet to Offnet --- Set to FALSE
Then Update
This allows external calls to be transferred both internally & externaly
2) Look at the Call Forwarding CSS on the line you are calling
Does this CSS have the Partitions which allow MOBILE calls
Alex
01-22-2012 11:05 PM
Hi Alex,
Under
Service ---> Service Parameters i was not able to see the option
PUB ADDRESS Service Call Manager. We are using CCm 4.0.
Roopesh
01-23-2012 01:40 AM
I just mean select the PUBLISHER server (You may have more than 1 server in the drop down depending on the build of your cluster), then the CALL MANAGER service
Alex
01-24-2012 03:16 AM
Hi ,Now we are able to Forward the Call to mobile.But We gets onle One ring in mobile and Call is Disconnecting Automatically.
Roopesh
01-24-2012 04:07 AM
Hi Roopesh
At least we are moving on a bit.
Can we see the debug isdn q931 of a forwarded call.
Alex
01-24-2012 04:18 AM
Hi Alex,
Do i need to do Normal debug Coomand
debug isdn q931 or any thing else
Roopesh
01-24-2012 04:26 AM
Roopesh
We want to see the forwarded call to try to work out why it is being cleared
router#
term mon
debug isdn q931
Make forwarded call
When you finish taking the trace
router#
un all
term no mon
Please include a few words of what numbers were called and what the destination of the forwarding should be.
Alex
01-24-2012 04:47 AM
Hi Alex,
Here it is
oh-rt2#term mon
oh-rt2#debug isdn
*Mar 1 20:48:51: %PS-3-MULTFAIL: There is more than one failure with the Power System 1; please resolve problems immediatelyq931
oh-rt2#
*Mar 1 20:49:10: ISDN Se4/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x822F
*Mar 1 20:49:16: ISDN Se4/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x822F
Date/Time i = 0x0C01181202
*Mar 1 20:49:16: %ISDN-6-CONNECT: Interface Serial4/0:30 is now connected to 64568381 N/A
*Mar 1 20:49:16: ISDN Se4/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x022F
*Mar 1 20:49:21: %PS-3-MULTFAIL: There is more than one failure with the Power System 1; please resolve problems immediately
*Mar 1 20:49:51: %PS-3-MULTFAIL: There is more than one failure with the Power System 1; please resolve problems immediately
*Mar 1 20:50:15: ISDN Se4/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x822F
Cause i = 0x8290 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
*Mar 1 20:50:15: %ISDN-6-DISCONNECT: Interface Serial4/0:30 disconnected from 64568381 , call lasted 59 seconds
*Mar 1 20:50:15: ISDN Se4/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x80FF
*Mar 1 20:50:15: ISDN Se4/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x022F
*Mar 1 20:50:15: ISDN Se4/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x822F
*Mar 1 20:50:21: %PS-3-MULTFAIL: There is more than one failure with the Power System 1; please resolve problems immediately
*Mar 1 20:50:51: %PS-3-MULTFAIL: There is more than one failure with the Power System 1; please resolve problems immediately
*Mar 1 20:51:21: %PS-3-MULTFAIL: There is more than one failure with the Power System 1; please resolve problems immediately
*Mar 1 20:51:40: ISDN Se4/0:15 Q931: RX <- SETUP pd = 8 callref = 0x68E2
Sending Complete
Standard = CCITT
Calling Party Number i = 0x2181, '9886770029'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '6300'
High Layer Compat i = 0x9181
*Mar 1 20:51:40: ISDN Se4/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xE8E2
*Mar 1 20:51:40: ISDN Se4/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0230
Standard = CCITT
Channel ID i = 0xA9839E
Exclusive, Channel 30
Called Party Number i = 0x80, '9902025093'
*Mar 1 20:51:40: ISDN Se4/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8230
*Mar 1 20:51:40: ISDN Se4/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8230
*Mar 1 20:51:43: ISDN Se4/0:15 Q931: TX -> PROGRESS pd = 8 callref = 0xE8E2
Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
*Mar 1 20:51:43: ISDN Se4/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8230
*Mar 1 20:51:43: ISDN Se4/0:15 Q931: TX -> ALERTING pd = 8 callref = 0xE8E2
Progress Ind i = 0x8188 - In-band info or appropriate now available
*Mar 1 20:51:43: ISDN Se4/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xE8E2
Cause i = 0x80AF - Resource unavailable, unspecified
*Mar 1 20:51:43: ISDN Se4/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0230
*Mar 1 20:51:43: ISDN Se4/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x68E2
*Mar 1 20:51:43: ISDN Se4/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xE8E2
*Mar 1 20:51:43: ISDN Se4/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8230
*Mar 1 20:51:43: ISDN Se4/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0230
*Mar 1 20:51:51: %PS-3-MULTFAIL: There is more than one failure with the Power System 1; please resolve problems immediately
*Mar 1 20:52:21: %PS-3-MULTFAIL: There is more than one failure with the Power System 1; please resolve problems immediately
oh-rt2#un all
All possible debugging has been turned off
oh-rt2#ter
*Mar 1 20:52:51: %PS-3-MULTFAIL: There is more than one failure with the Power System 1; please resolve problems immediatelym term no mon
oh-rt2#exit
Roopesh
01-24-2012 05:17 AM
We see the 2 calls being set up
Call Refs incoming 68E2 & outgoing 0230
The router is clearing both of these calls with a cause code
This usually infers that there is a codec issue
Can you post the show runn from the gateway
Alex
01-24-2012 05:26 AM
Hi Alex,
Please find the result for sh run
oh-rt2#sh run
Building configuration...
Current configuration : 6276 bytes
version 12.3
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname oh-rt2
boot-start-marker
boot system flash c3745-advipservicesk9-mz.123-26.bin
boot-end-marker
logging buffered 4096 notifications
enable secret 5 $1$AgBh$dCd1NSglSXBbZXmjcdO/I.
clock timezone IST 5 30
no network-clock-participate slot 2
no network-clock-participate slot 4
voice-card 2
dspfarm
--More-- voice-card 4
dspfarm
dsp services dspfarm
no aaa new-model
ip subnet-zero
ip cef
ip domain name A.com
ip audit po max-events 100
voice hunt user-busy
voice rtp send-recv
voice class codec 1
--More-- !
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.10.14.11
ccm-manager config
fax interface-type fax-mail
controller E1 2/0
controller E1 2/1
framing NO-CRC4
controller E1 4/0
framing NO-CRC4
--More-- pri-group timeslots 1-31
description For Outgoing
ip tcp synwait-time 13
interface Multilink1
bandwidth 256
ip address 172.16.16.45 255.255.255.252
ip tcp header-compression iphc-format
ppp multilink
ppp multilink group 1
ip rtp header-compression iphc-format
interface FastEthernet0/0
ip address 10.10.14.5 255.255.255.0
ip broadcast-address 10.10.14.255
ip accounting output-packets
ip nbar protocol-discovery
ip route-cache flow
--More-- no ip mroute-cache
duplex auto
speed auto
h323-gateway voip bind srcaddr 10.10.14.5
interface Serial0/0
description Circuit #1 initiating in India via Bharti
bandwidth 128
no ip address
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
clock rate 2000000
ppp multilink
interface FastEthernet0/1
ip address 10.10.3.8 255.255.255.0
duplex auto
speed auto
no cdp enable
interface Serial0/1
--More-- description Circuit #2 initiating in India via BSNL
bandwidth 128
no ip address
no ip route-cache
no ip mroute-cache
clock rate 2000000
interface Serial0/2
description initiating in India via TATA
bandwidth 128
no ip address
encapsulation ppp
clock rate 2000000
ppp multilink
interface Serial0/3
no ip address
shutdown
clock rate 2000000
no cdp enable
--More-- interface Serial2/1:15
no ip address
encapsulation hdlc
no cdp enable
interface Serial4/0:15
no ip address
encapsulation hdlc
no cdp enable
ip classless
ip route 10.10.0.0 255.255.0.0 10.10.14.1
ip route 172.18.252.0 255.255.255.192 10.10.14.1
ip http server
no ip http secure-server
logging trap errors
access-list 1 permit 10.10.3.18 log
--More-- access-list 1 deny any
access-list 2 permit 10.10.3.18 log
access-list 2 deny any
dialer-list 1 protocol ip permit
snmp-server community public RO 1
snmp-server community private RW 2
snmp-server location OH/BLR/IN/
snmp-server contact
snmp-server enable traps tty
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
cptone IN
timeouts interdigit 3
connection plar 100
voice-port 1/1/1
--More-- cptone IN
connection plar 100
voice-port 2/1:15
connection plar 500
voice-port 4/0:15
connection plar 500
mgcp
mgcp call-agent 10.10.14.11 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
--More-- !
sccp local FastEthernet0/0
sccp
sccp ccm 10.10.14.11 priority 1
dspfarm rtp timeout 60
dial-peer cor custom
dial-peer voice 3 pots
application mgcpapp
incoming called-number 8025053.T
direct-inward-dial
dial-peer voice 4 pots
application mgcpapp
dial-peer voice 5 pots
application mgcpapp
dial-peer voice 3000 voip
--More-- destination-pattern 3...
session target ipv4:160.100.160.151
dial-peer voice 9999 voip
destination-pattern 9T
dial-peer voice 6 pots
application mgcpapp
dial-peer voice 2 voip
destination-pattern ...
codec g711ulaw
no vad
dial-peer voice 14 pots
destination-pattern 0T
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
--More-- direct-inward-dial
port 4/0:15
dial-peer voice 101 voip
destination-pattern 7..
codec g711ulaw
no vad
dial-peer voice 102 voip
destination-pattern 8..
codec g711ulaw
no vad
dial-peer voice 103 voip
destination-pattern 9..
--More-- codec g711ulaw
no vad
dial-peer voice 104 voip
codec g711ulaw
no vad
dial-peer voice 105 voip
destination-pattern 6..
codec g711ulaw
no vad
no vad
dial-peer voice 30 pots
preference 2
destination-pattern *5T
dial-peer voice 77 pots
preference 2
destination-pattern *7T
dial-peer voice 29 pots
preference 1
port 1/1/0
dial-peer voice 78 pots
preference 1
port 1/1/1
num-exp 8025053... ...
--More-- gateway
banner motd ^C
!!!AUTHORIZED ACCESS ONLY !!!
Hostname : OH-RTR2.
Contact :IS Helpdesk
!!! AUTHORIZED ACCESS ONLY !!!
^C
line con 0
transport output all
line aux 0
transport preferred none
transport output none
line vty 0 5
password 7 1511021F0725
login
transport input all
ntp clock-period 17180604
--More-- ntp server 10.10.8.1
Thnks
Roopesh
