Unable to get user report
waqas sardar
Dear all,
Please find the attachment,I am getting following error,while i am trying to get user repot and following services are not running
Cisco CDR Repository Manager
Cisco CAR Scheduler
I tried to run these service ,but fail.
Waqas
8 Replies 8
Aman Soi
Hi Waqas,
What is CUCM version u are using?
Tried opening the files, but junk is coming.
Can u attach again?
regds,
aman
Hi Aman,
Now try again .Its cucm 8.6
Hi Waqas,
Is this fresh installation?
Please check the settings in Service Parameters, select Cisco Call MAnager
          CDR Enabled Flag = True
Cluster Wide PArameters(Device-General)
      Call Diagnostics Enabled = Enabled Regardless of CDR Enabled Flag
regds,
aman
CUCM upgraded from 7.1 to 8.6.
above mention settings are fine.
Hi Waqas,
Did u try to restart the CDR reporsitory MAnager and CAR Scheduler  services or they start and stop immediately?
IS CUCM 8.6 now running on VM or MCS servers?
regds,
aman
Yes,I tried by CLI and GUI,but failed to start these services.I am unable to restart server because its live envirment.
On MCS server
Get In touch with TAC
Tapan
Hi Waqas,
I could find some bugs related to CDR Repository Service not starting /functioning but the CUCM version is different.Also, the resolution requires involvement of TAC.
Can u restart the server and check else open the case..
CAR Scripts check substring of process name instead of the Process PID.
CSCsj20458
Description
Symptom:
Cisco CDR Repository Manager Service not starting.
Conditions:
Cisco CDR Repository Manager Service not starting. Service Manager thinks that the service is still running and its not starting the service.
06/04/2007 18:40:13.702 ServM|Cisco CDR Repository Manager : Restart
Denied : Restarted 3 times in 1200
secs|
Workaround:
from ssh login,
1. ps -ef|grep cdrrep
2. find all the PIDs in the listing,
3. kill -9
4. try to start the service again.
CDR Repository Manager not functioning
CSCsb32320
Description
Symptom:
CDR Repository Manager is not functioning in the said build. It is not creating the various folders like cdr_repository, temp, trans under /var/log/active/cm/ file system. Further on investigation it was seen that it is failing to do all the other functions like polling for data, etc. As a result CDR Del Module, CAR and all other functions related to CAR cannot work completely.
Conditions:
Standard Testing condition.
Workaround:
pryftool --system cm --hive dbl --set connectionpool=0
Further Problem Description:
NA
CSCsc84190Restart "Cisco CDR Repository   Manager" service always fail
regds,
aman
