12-21-2023 04:28 AM
One of my clients had a power outage that caused CUCM, IM&P and UCCX to restart.
After this, users are unable to login to IP Phone Agent using IP Communicator.
They receive a message stating that the user is already logged in, and there are 2 options: Press 1 to disconnect the user and Press 2 to return to login window. But pressing 1 does nothing, it just stays on this error page.
I created a new user to test, one that hadn't been using IPPA before and the issue happened to this one too.
I have checked CUCM and UCCX services, they are running normally. Servers are on version 8.6
Has anyone encountered an issue like this before?
Solved! Go to Solution.
12-21-2023 01:13 PM
Glad that helped my old post ‘:-)’
Infact the next would be to remove and readd the agent phone
Thanks again
Cheers
Carlo
12-21-2023 09:34 AM
Hi ,
Go on CUCM Serviceability page a on Tools ---> Contrl Center (Feature Services) and restart Cisco CTI Manager Service.
Se if it makes the difference.
Carlo
12-21-2023 11:36 AM
Hello Carlo,
Thank you for the response.
After opening this thread, I found this post: https://community.cisco.com/t5/ip-telephony-and-phones/unable-to-login-cisco-phone-agent/m-p/2630195#M291241.
Followed it, removed the agents from resources and added again, now it's working again.
12-21-2023 01:13 PM
Thanks again
Cheers
Carlo
