Unable to Login to Jabber for Windows
lyle.stevens
We are running CUCM 8.6.2 and CUPS 8.6. We are trying to get Jabber for windows working but we keep getting the error "Cannot Communicate to Server". The presence diagnostics shows everything is fine and also our users says they are licensed for Jabber. We want to deploy Jabber for IM purposes only, what might we be missing?
Jaime Valencia
I'd start by reviewing DNS resolution works and that you can log into CCMuser with those credentials.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Dennis Mink
Could be a number of things,  before you log in, check the connection type and make sure you log into on premise presence not webex connect. could also be that your node name in presence is different from what you are logging into, so TLS will crap itself.
send us the problem report, says more than a thousand words
Please remember to rate useful posts, by clicking on the stars below.
Don't have any experience with Presence but I am logging into the premise based and the am able to login to the end user page with the same credentials. I have added the problem report from the jabber client.
