07-24-2012 12:34 PM - edited 03-16-2019 12:21 PM
I just set up a two 7940 SIP phones. Ive been trying for days to receive/send calls with no luck.I am using a CISCO 1760 router and I have installed a 4.3 CME version. I configured the phones according to many of the postings and I came to the conclusion that my problem is the way I configured the phones on the router. I know by fact that the phones have access to URL services, and they can send and receive call whithsin my local network. . Please, can anybody point me on the right direction?. Thanks.
Building configuration...
Current configuration : 4825 bytes
! Last configuration change at 14:51:12 CA1_DST Tue Jul 24 2012
! NVRAM config last updated at 14:44:54 CA1_DST Tue Jul 24 2012
version 12.4
hostname VOICE
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EST -5
clock summer-time CA1_DST recurring
crypto pki trustpoint TP-self-signed-990320880
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-990320880
revocation-check none
rsakeypair TP-self-signed-990320880
crypto pki certificate chain TP-self-signed-990320880
certificate self-signed 01
9F53E051 E687F356 AFC69E0A 34521D8D 29046BC6 47CE3C3E 54E698F1
6E0B7166
DBA9FB31 B2AC424F 572A4081 0248862E 689A3611 E853C8B6 AAA74852
AFFA514A
431EF188 75EEFA87 2C394197 AB99B453 D31E4349 803D1383 6B2B84F1 2002A8
quit
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.18.1 192.168.18.200
ip dhcp pool VOICE_SCOPE
network 192.168.18.0 255.255.255.0
default-router 192.168.18.200
option 150 ip 192.168.18.200
dns-server 4.2.2.2
ip name-server 192.168.13.2
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
registrar server expires max 600 min 60
voice register global
mode cme
source-address 192.168.18.200 port 5060
max-dn 144
max-pool 24
load 7960-7940 P0S3-08-6-00
timezone 13
url service http://phone-xml.berbee.com/cgi-bin/weather.pl
file text
create profile sync 000124025500339A
ntp-server 134.214.100.6 mode unicast
voice register dn 1
number 7001
name Ubuntu
label Core7
voice register dn 2
number 7005
name ccna
label IPccna
voice register dialplan 1
type 7940-7960-others
pattern 1 7
voice register pool 1
id mac 0013.1A6C.XXXX
type 7940
number 1 dn 1
dtmf-relay rtp-nte sip-notify
codec g711ulaw
voice register pool 2
id mac 000B.5F80.XXXX
type 7940
number 1 dn 2
username 561623XXXX
username username privilege 15 secret 5 $1$W2PC$WHkf.nvnA6SLMAaZsxwSl0
archive
log config
hidekeys
interface Loopback0
ip address 192.168.254.254 255.255.255.255
interface FastEthernet0/0
ip address 192.168.18.200 255.255.255.0
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.18.1
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
tftp-server flash:/phone/7940-7960/P0S3-08-6-00.loads alias
P0S3-08-6-00.loads
tftp-server flash:/phone/7940-7960/P0S3-08-6-00.sb2 alias
P0S3-08-6-00.sb2
tftp-server flash:/phone/7940-7960/P003-08-6-00.bin alias
P003-08-6-00.bin
tftp-server flash:/phone/7940-7960/P003-08-6-00.sbn alias
P003-08-6-00.sbn
control-plane
dial-peer voice 13 voip
preference 1
session protocol sipv2
session target sip-server
incoming called-number 561623XXXX
dtmf-relay rtp-nte
codec g711ulaw
line con 0
password password
login
line aux 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
ntp clock-period 17179988
ntp server 134.214.100.6
end
07-31-2012 04:13 PM
You're welcome, please remember to rate useful posts clicking on the stars below.
