03-21-2014 07:21 AM - edited 03-16-2019 10:13 PM
Hi !
Does anyone know if this issue has ben solved in CUCM V10 ?
Thank you,
Christian.
Solved! Go to Solution.
03-21-2014 03:36 PM
Christian,
The bug is still in an OPEN status.
It states that the known affected releases are only CUCM8.6.2xxx.
You should raise a TAC and tell them that the bug is also affecting your CUCM Ver/Release
They say the workaround is to use H323
Hope this helps
Alex
03-22-2014 02:36 PM
Hi Christian,
The workaround in place is to you use the gateway as H.323.
if you do land opening a ticket with TAC, the same solution will be given for the bug you posted.
As of now the bug has not been resolved on CUCM 10 and is being worked on i believe.
So eventually you'll have to wait for a update for fix in the next release on the CUCM.
Rate the post accordingly.
Kevin
03-21-2014 03:36 PM
Christian,
Hope this helps
Alex
03-24-2014 01:13 AM
Hi folks !
I have already created a case with TAC and your answers are accurate. It seems obvious that Cisco has other priorities than developing a "small" router in the CUCM environment!
Regards.
Christian.
03-22-2014 02:36 PM
Hi Christian,
Kevin
03-24-2014 01:13 AM
Hi folks !
Regards.
Christian.
