Unable to save recording due to SSL certificate error
jac_tenke
Hi! All, I'm using Unity Connection 10.5.1. I'm unable to save a recorded message for my call handler with the message below return by the system.
"Unable to save recording due to SSL certificate error"
Any help to solve this matter will be helpfull.
George Thomas
Level 10
Level 10
There are multiple discussions:
https://supportforums.cisco.com/discussion/12368831/unable-save-recording-due-ssl-certificate-errors
https://supportforums.cisco.com/discussion/12363081/unity-connection-comic-java-drama-clarification-would-be-appreciated
Please rate useful posts.
kkoeper12
Level 3
Level 3
I noticed the Java version 8 breaks the media master bar. Need to use the latest version 7 available and set the security to the minimum. You may still get an error message but the recording will actually be saved if you go back and check it.
