Unable to Upgrade 7961-G to new SIP Firmware
zhir
Dear Cisco community,
The 7961 that i have it used to run SCCP I upgraded it to SIP cmterm-7941_7961-sip.8-0-4SR3A. Everything went well but i realized that my CME is only compatible with cmterm-7941_7961-sip.9-2-1. So when i try to load any other firmware that is newer than cmterm-7941_7961-sip.8-0-4SR3A it goes into a boot loop and it only gets the terms61.loads file over and over.
Appreciate your help,
Hi @zhir
Before you can upgrade to 9.1 or later, you need to upgrade to release 8.5.2 than you can proceed further.
Carlo
Please rate all helpful posts "The more you help the more you learn"
As @Carlo Poggiarelli suggested, you need to upgrade to intermediate versions first. Begin with upgrading to 8.5(2), then to 9.2-1. The screenshot is for 9.2.3, but it applies to your version as well.
Response Signature
