Unable to use Join Softkey with CME 7.1
josh.l.anderson
When I try to use the Join softkey to Join two participants together, I receive a "Cannot Complete Conference" error. However, conferencing itself seems to be working fine (taken from a 3 person test conference):
KC_VG_1#sho sccp conn
sess_id    conn_id      stype mode     codec   sport rport ripaddr
3221815305 131096       conf  sendrecv g711u   16788 2000  10.100.100.253
3221815305 131095       conf  sendrecv g711u   16546 2000  10.100.100.253
3221815305 131094       conf  sendrecv g711u   16770 2000  10.100.100.253
Total number of active session(s) 1, and connection(s) 3
KC_VG_1#sho dsp dsp all
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    1   24.3.2   UP     N/A  FREE  xcode  3      -         -         -
0    3   24.3.2   UP     1    USED  conf    2      0x24F       4343      4391
0    3   24.3.2   UP     1    USED  conf    2      0x251       4343      0
0    3   24.3.2   UP     1    USED  conf    2      0x253       4343      4376
0    3   24.3.2   UP     N/A  FREE  conf   2      -         -         -
0    5   24.3.2   UP     N/A  FREE  mtp    1      -         -         -
0    5   24.3.2   UP     N/A  FREE  xcode  3      -         -         -
Total number of DSPFARM DSP channel(s) 20
I've tried changing from hardware to software conferencing and tried fiddeling with a few other things to no avail.
The user guide doesn't even document Join for CME. I see the feature documented in the admin guides, however, so I assume it should be available for use. I tried using Join with one call on hold and one call active and I tried using Join with two calls on hold. Both tests give the same result.
Thanks in advance for your assistance.
You need to add a SELECT key in the
ephone template for softkeys hold.Then when you have the 2 calls on hold press the select key for both lines, you will see a check box.
after both are selected then press join.
6 Replies 6
Jaime Valencia
Exactly how are you trying to use the join softkey???
What are you doing/pressing on the phone??
Soft Keys for Conference Functions
Join—Joins an established call to a conference. You must first press Select to choose each connected call that you want to join in a conference, then press Join to join the selected calls to the conference.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1011236
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
From my phone (Phone A), I call Phone B. I place that call on hold. I then place a new call to Phone C. I then try to join Phone B into the call.
So, I have a single line key on my phone (octo-line) with an active call and an on-hold call. At this point, I have an active Join key. If I arrow up to the on-hold call, then press Join, I still get the conference error (is this what it means by pressing Select?).
I ran this scenario in IP Communicator so I could get a screenshot.
Have you tried with a dual-line DN ?
Just tested with dual-line DN as the originating caller (the one trying to use join). Still get the exact same thing.
Thank you. For some reason, I totally didn't get that from the documentation.
If only features would work the way I think they should rather than the way Cisco thinks they should ;-)
