unallocated number
Pawan Arora
Hi ,
I am facing issue with my outgoing calls, i have configured mgcp on the remote location with my call manager 8.6.
I am unable to dial outgoing number but my incoming numbers are working fine. Please help me on this.Please find below the debug isdn q931 and debug voice ccapi in out output from the mgcp gateway.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.07.15 16:56:12 =~=~=~=~=~=~=~=~=~=~=~=
isdn q931
debug isdn q931 is        ON.
COLRouter_01#debug voice cc
COLRouter_01#debug voice ccapi ino
COLRouter_01#debug voice ccapi inout
voip ccapi inout debugging is on
COLRouter_01#
Jul 15 11:26:34.501: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x49302BC4, Interface Type=6, Destination=, Mode=0x9,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=D000000002ef20a0000000F500000004)
Jul 15 11:26:34.501: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 15 11:26:34.501: :cc_get_feature_vsa malloc success
Jul 15 11:26:34.501:  cc_get_feature_vsa count is 1
Jul 15 11:26:34.505: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 15 11:26:34.505: :FEATURE_VSA attributes are: feature_name:0,feature_time:1250622536,feature_id:61269
Jul 15 11:26:34.505: //61274/C4A19212B312/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Jul 15 11:26:34.505: //61274/C4A19212B312/CCAPI/ccCallSetContext:
   Context=0x4913D7A8
Jul 15 11:26:34.505: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x48616C94, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
Jul 15 11:26:34.505: :cc_get_feature_vsa malloc success
Jul 15 11:26:34.505:  cc_get_feature_vsa count is 2
Jul 15 11:26:34.505: :FEATURE_VSA attributes are: feature_name:0,feature_time:1250622312,feature_id:61270
Jul 15 11:26:34.505: //61275/C4A19212B312/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
Jul 15 11:26:34.505: //61275/C4A19212B312/CCAPI/ccCallSetContext:
   Context=0x4913C308
Jul 15 11:26:34.509: //61275/C4A19212B312/CCAPI/cc_api_call_connected:
   Interface=0x48616C94, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Jul 15 11:26:34.509: //61274/C4A19212B312/CCAPI/cc_api_call_proceeding:
   Interface=0x49302BC4, Progress Indication=NULL(0)
Jul 15 11:26:34.509: //61274/C4A19212B312/CCAPI/cc_api_call_connected:
   Interface=0x49302BC4, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
Jul 15 11:26:34.513: //61274/C4A19212B312/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x49199020, Call Id=61274
Jul 15 11:26:34.513: //61274/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0xEF5A, digit_event=0x1, enable=TRUE, consume=FALSE)
Jul 15 11:26:34.513: //61274/C4A19212B312/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=61274
Jul 15 11:26:34.513: //61274/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x49302BC4, callID=0xEF5A, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Jul 15 11:26:34.513: //61274/C4A19212B312/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x49302BC4, Call Id=61274
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
Jul 15 11:26:34.513: //61274/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x49199234, callID1=0xEF5A, callID2=0xEF5B, tag=0x0)
   (confID=0x49199234, callID1=0xEF5A, gcid=0-0-0-0, tag=0x0)
Jul 15 11:26:34.513: //61275/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x49199234, callID2=0xEF5B, gcid=0-0-0-0, tag=0x0)
Jul 15 11:26:34.513: //61274/C4A19212B312/CCAPI/ccConferenceCreate:
   Conference Id=0x49199234, Call Id1=61274, Call Id2=61275, Tag=0x0
Jul 15 11:26:34.513: //61274/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x7894, Source Interface=0x49302BC4, Source Call Id=61274,
   Destination Call Id=61275, Disposition=0x0, Tag=0xFFFFFFFF
Jul 15 11:26:34.513: //61275/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x7894, Source Interface=0x48616C94, Source Call Id=61275,
   Destination Call Id=61274, Disposition=0x0, Tag=0x0
Jul 15 11:26:34.513: //61274/C4A19212B312/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x7894, Destination Call Id=61275)
Jul 15 11:26:34.513: //61275/C4A19212B312/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x7894, Destination Call Id=61274)
Jul 15 11:26:34.513: //61274/C4A19212B312/CCAPI/cc_api_caps_ind:
   Destination Interface=0x48616C94, Destination Call Id=61275, Source Call Id=61274,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Jul 15 11:26:34.513: //61275/C4A19212B312/CCAPI/cc_api_caps_ind:
   Destination Interface=0x49302BC4, Destination Call Id=61274, Source Call Id=61275,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
Jul 15 11:26:34.513: //61275/C4A19212B312/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=758)
Jul 15 11:26:34.513: //61274/C4A19212B312/CCAPI/cc_api_caps_ack:
Jul 15 11:26:34.517: //61274/C4A19212B312/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x49302BC4, Call Id=61274
Jul 15 11:26:34.517: //61274/C4A19212B312/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x7894, Call Id1=61274, Call Id2=61275
Jul 15 11:26:34.537: //61274/C4A19212B312/CCAPI/cc_api_voice_mode_event:
   Call Id=61274
   Call Entry(Context=0x4913D7A8)
Jul 15 11:26:34.541: //61274/C4A19212B312/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms)
   Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
Jul 15 11:26:34.541: //61274/C4A19212B312/CCAPI/ccRestartDigitTimeoutMsec:
   Digit Timeout=0, Call Id=61274
Jul 15 11:26:34.541: //61274/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
Jul 15 11:26:34.541: //61274/C4A19212B312/CCAPI/ccCallReportDigits:
Jul 15 11:26:34.541: //61274/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Jul 15 11:26:34.541: //61274/C4A19212B312/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
Jul 15 11:26:34.625: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0004
    Sending Complete
    Bearer Capability i = 0x8090A3
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA98381
        Exclusive, Channel 1
    Calling Party Number i = 0x0081, '117487021'
        Plan:Unknown, Type:Unknown
    Called Party Number i = 0x80, '0112977185'
Jul 15 11:26:34.645: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8004
Jul 15 11:26:34.717: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8004
    Cause i = 0x8081 - Unallocated/unassigned number
Jul 15 11:26:34.769: //61274/C4A19212B312/CCAPI/ccCallModifyExtended:
   Nominator=0x49198F58, Params=0x491981A8, Call Id=61274
Jul 15 11:26:34.769: //61275/C4A19212B312/CCAPI/ccCallModify:
   Nominator=0x18E30, Params=0x491983A8, Call Id=61275
Jul 15 11:26:34.769: //61274/C4A19212B312/CCAPI/cc_api_call_modify_done:
Jul 15 11:26:34.769: //61275/C4A19212B312/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x48616C94, Call Id=61275
Jul 15 11:26:34.853: //61274/C4A19212B312/CCAPI/ccCallModifyExtended:
Jul 15 11:26:34.853: //61275/C4A19212B312/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x491983A8, Call Id=61275
Jul 15 11:26:34.853: //61274/C4A19212B312/CCAPI/cc_api_call_modify_done:
Jul 15 11:26:34.857: //61275/C4A19212B312/CCAPI/cc_api_call_modify_done:
Jul 15 11:26:34.937: //61274/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0xEF5A, digit_event=0x0, enable=FALSE, consume=FALSE)
Jul 15 11:26:34.937: //61274/C4A19212B312/CCAPI/ccCallReportDigits:
Jul 15 11:26:34.937: //61274/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x49302BC4, callID=0xEF5A, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Jul 15 11:26:34.937: //61274/C4A19212B312/CCAPI/cc_api_call_report_digits_done:
Jul 15 11:26:34.937: //61275/C4A19212B312/CCAPI/ccGetCallStatistics:
   Call Stats=0x4B2A2DBC, Call Id=61275
Jul 15 11:26:34.937: //61274/C4A19212B312/CCAPI/ccConferenceDestroy:
   Conference Id=0x7894, Tag=0x0
Jul 15 11:26:34.937: //61274/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=61275, Disposition=0x0, Tag=0x0
Jul 15 11:26:34.937: //61275/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jul 15 11:26:34.937: //61274/C4A19212B312/CCAPI/cc_generic_bridge_done:
Jul 15 11:26:34.941: //61274/C4A19212B312/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jul 15 11:26:34.941: //61274/C4A19212B312/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jul 15 11:26:34.941: //61275/C4A19212B312/CCAPI/ccCallDisconnect:
Jul 15 11:26:34.949: //61275/C4A19212B312/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48616C94, Tag=0x0, Call Id=61275,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jul 15 11:26:34.949: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 15 11:26:34.949: :cc_free_feature_vsa freeing 4A8AFB60
Jul 15 11:26:34.949:  vsacount in free is 1
Jul 15 11:26:34.953: //61274/C4A19212B312/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49302BC4, Tag=0x0, Call Id=61274,
Jul 15 11:26:34.953: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 15 11:26:34.953: :cc_free_feature_vsa freeing 4A8AFC40
Jul 15 11:26:34.953:  vsacount in free is 0
Jul 15 11:26:35.033: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0004
Jul 15 11:26:35.037: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8004u all
All possible debugging has been turned off
COLRouter_01#term no mon
COLRouter_01#
Pawan Arora
21 Replies 21
In the log the pattern is matched with Outgoing Dial-peer=0 , this usually means that there is no matching , can you please post the sh run or at least the dial-peers along with the MGCP config.
Amer
Hi Amer,
Please find below the configuration
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.07.15 17:27:05 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 7409 bytes
! Last configuration change at 17:18:21 GMT Sun Jul 15 2012 by gstvnda
! NVRAM config last updated at 16:44:55 GMT Sun Jul 15 2012 by gstvnda
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname COLRouter_01
boot-start-marker
boot-end-marker
card type e1 0 0
logging message-counter syslog
no logging console
enable secret 5 $1$RtSC$r0IsgteoeKruFK3xcpECf.
enable password 7 07083258582952001B170803097F
aaa new-model
aaa group server tacacs+ innodacs
server 10.120.13.125
server 10.100.13.125
server 10.120.0.125
server 10.100.0.125
aaa authentication login default group innodacs local
aaa authentication enable default enable
aaa authorization console
aaa authorization exec default group innodacs local
aaa authorization commands 15 default group innodacs local
aaa accounting exec default
action-type start-stop
group innodacs
aaa accounting commands 1 default
group innodacs
aaa accounting commands 15 default
group innodacs
aaa accounting connection default
group innodacs
aaa accounting system default
action-type stop-only
group innodacs
--More--                           !
aaa session-id common
clock timezone GMT 5 30
network-clock-participate wic 0
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.140.3.1 10.140.3.50
ip dhcp excluded-address 10.140.3.252 10.140.3.254
ip dhcp excluded-address 10.140.5.1 10.140.5.50
ip dhcp excluded-address 10.140.5.252 10.140.5.254
ip dhcp pool IP_PHONE
   network 10.140.3.0 255.255.255.0
   default-router 10.140.3.254
   dns-server 10.140.0.8 10.140.0.9
   option 150 ip 10.120.3.29 10.120.3.30
   lease 15 23
ip dhcp pool test
ip dhcp pool VIDEO_STATION
   network 10.140.5.0 255.255.255.0
   default-router 10.140.5.254
   lease 15 23
ip dhcp pool IP_PHONE_Galle
   network 10.130.3.0 255.255.255.0
   lease 15 23
no ip domain lookup
ip domain name innodata.com
no ipv6 cef
isdn switch-type primary-net5
voice rtp send-recv
voice service voip
--More--                           !
voice translation-rule 1
rule 1 /^748\(.*\)/ /\1/
voice translation-profile InBound
translate called 1
voice-card 0
application
service cmm http://10.150.3.30:8080/ccmivr/pages/IVRMainpage.vxml
archive
log config
  hidekeys
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
description "COLE1-PRI--INT-INFO-E1 0/0/0"
controller E1 0/0/1
shutdown
interface GigabitEthernet0/0
description "ETHT_LAN-ETH_SW--INT-INFO-GE 0/0"
ip address 10.140.3.31 255.255.255.0
duplex auto
speed auto
--More--                           !
interface Service-Engine0/0
description "COLCUE---INT-INFO-SE0/0"
ip unnumbered GigabitEthernet0/0
service-module ip address 10.140.3.34 255.255.255.0
service-module ip default-gateway 10.140.3.31
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
description "COLE1_SERIAL--INT-INFO-S0/0/0:15"
no ip address
encapsulation hdlc
isdn overlap-receiving T302 2000
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip default-gateway 10.140.3.254
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.140.3.254
ip route 0.0.0.0 0.0.0.0 10.140.1.1
ip route 10.140.3.34 255.255.255.255 Service-Engine0/0
no ip http server
no ip http secure-server
ip tacacs source-interface GigabitEthernet0/0
logging history emergencies
logging trap notifications
logging facility local3
logging 10.100.3.38
logging 10.100.51.13
logging 10.120.0.123
logging 10.120.13.123
logging 10.120.1.150
access-list 1 permit 10.120.13.123
access-list 1 permit 10.120.0.123
access-list 1 permit 10.100.51.98
access-list 1 permit 10.120.51.164
snmp-server community mpcolro RO
tacacs-server host 10.120.0.125 key 7 075E2F421E0D3911375F2823283C7B75387E2736
tacacs-server host 10.100.0.125 key 7 040A05085F256C5A295426383E1D5C553A66363C
tacacs-server host 10.120.13.125 key 7 03555505560B01586E443A2A3B045B5D14673930
tacacs-server host 10.100.13.125 key 7 101F07175513321F2C490904083E6364325E1502
control-plane
--More--                           !
voice-port 0/0/0:15
ccm-manager redundant-host 10.120.3.30
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.120.3.30
ccm-manager config
mgcp
mgcp call-agent 10.120.3.30 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 7800 voip
destination-pattern 7800
session protocol sipv2
session target ipv4:10.140.3.34
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 7801 voip
destination-pattern 7801
codec g711ulaw
no vad
dial-peer voice 7802 voip
service cmm
session target ipv4:10.150.3.30
incoming called-number 7802
codec g711ulaw
no vad
dial-peer voice 7803 voip
service cmm
session target ipv4:10.150.3.29
codec g711ulaw
--More--                           banner login ^C
Did you assign a CSS on the gateway that can reach the IP Phone you are dialing from ?
Amer
On the call manager , from the gateway assign to the E1 PRI a CSS on the inbound , make sure it has all the partition to all the users partitions so the call will br routed from the gateway to the IP Phones.
Amer
Amer,
is there any compatibility issue with the CISCO IOS 12.4 (22) T with CUCM 8.6.2
Technically no problem , cisco says that in case of MGCP it doesn't matter however it is best to upgrade to 15
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/unified/communications/system/versions/IPTMtrix.html#wp1016708
Also cisco says that in case it didn't work (if you open a TAC you must upgrade to 15)
Amer
Yes, CSS is already there on the gateway .
I have applied a css which has all the partition, but still got the same error."your call cannot be completed as dialed:
One last thing , add the below dial-peer to the gateway , restart it and try :
dial-peer voice 1 pots
service mgcpapp
Amer
AMer, do want me to restart the router or just reset it from the call manager
rofallar
The carrier is returning the unalloc message. It looks like you are trying to reach an international number but the number looks rather short. Is 0112977185 the entire dnis you are dialing?
Just restart the gateway and test.
ok Amer, i have reloaded the gateway and got the same issue.
HI Ronald,
Here is my setup
1. I have CUCM in India
2. MGCP router in Colombo and users are trying to call number which is local for them.
3. Colombo users and gateway are using separate partition and css for their calling.
