ā01-20-2014 04:44 AM - edited ā03-16-2019 09:20 PM
Please can someone explain me the type and plan terms in reference to translation rules.
ā01-20-2014 06:21 AM
Isdn providers use type and plan to identify of call is local, national, international, etc. however at time you want to change that as it would only apply under perfect conditions. As an example inernational calls often fail with calling party plan/type defined so you change it to unknown/unknown via the TP.
Chris
ā01-21-2014 12:10 AM
Hi Chirs,
Thanks for your reply,but still i m confused.
So you mean that type and plan are only used when you have ISDN connections.what about if i m using E1.?.
I want to know what type and plan means.
Hope i am clear in putting the question.
ā01-21-2014 12:28 AM
Please have a look at this thread: https://supportforums.cisco.com/thread/2059956
Please rate all the useful posts
ā01-21-2014 12:29 AM
Hi.
E1 stiil uses ISDN standard and what Chris (+5 "C") mentioned also applyes to it
If you look at a debug isdn q931 output, you will see info like this:
Jan 21 08:23:56.048: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x002B
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838B
Exclusive, Channel 11
Calling Party Number i = 0x0181, 'XXXXXXXX'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xA1, 'XXXXXXXX'
Plan:ISDN, Type:National
High Layer Compat i = 0x9181
In this case, as highlited, numbering plan is ISDN and Type is National for Called party number and ISDN and Unknown for calling party
With a translation rule you can modify these valuse according to your needs both for calling and called party
Carlo
Please rate all helpful posts
"The more you help the more you learn"
