06-28-2011 10:47 AM - edited 03-16-2019 05:40 AM
Hey All
I need to understand on a CME active call session which dial-peer was used. Which show command will help to identify this piece of information.
cheers
Paul
Solved! Go to Solution.
06-28-2011 10:56 AM
Hi Paul,
One of the most useful debugs for watching dial-peer matching is 'debug voip dial-peer'
HTH,
Chris
06-28-2011 11:03 AM
Hi Paul,
" Sh call act voi bri" will show you voice session and dialpeer info(PID).
Vandana
06-28-2011 11:08 AM
You can use show voice call status
Hope it helps, please rate if it does.
Adrian
06-28-2011 10:56 AM
Hi Paul,
HTH,
Chris
06-28-2011 11:03 AM
Hi Paul,
Vandana
06-28-2011 11:08 AM
Adrian
06-28-2011 01:00 PM
Thanks all
cheers
Paul
