06-28-2011 10:08 AM - edited 03-16-2019 05:40 AM
I have 7975 IP phones & CUCM 7.1.5b SU4...I have configured 2 DN for 7975 phones, however whenever i try to use the 2nd DN & dial some outbound calls, it's not happening...Partition/CSS/RP is perfectly fine..
Do i need to do anything specific to enable this feature??
06-28-2011 10:31 AM
But exactly what happens?
What error/message do you get?
And exactly what's the process you're doing to dial?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
06-28-2011 12:46 PM
06-28-2011 12:49 PM
Then "Partition/CSS/RP is perfectly fine.." is definitely not true, that means something in your CSS/partitions is wrong.
Vasil already mentioned that:
If you hear "Call can not be completed as dialed" message upon a dial attempt, it has been prompted from the UCM, and, then it is usually a call routing issue. Re-check sequentially CSS, Partitions, Dial Patterns, Route Groups, Alternate call routing if any.
java
06-28-2011 10:41 AM
There shall be nothing special for secondary line, it should have similar configuration as the primary one, except the DN of course.
If you do not hear the message, re-check that you have proper calling-id handling, as many PTT/ITSPs would reject calls that do not have it the right way. This includes proper prefix, format (E.164 for an example), DID within assigned range, removal of any digits/signs, that have local to the UCM significance (PreDot or trailing-#, etc.). In this case re-check Route Group settings from within the Route List page, any Translation CSS and patterns, gateway/trunk configuration.
You can also try to dial another DN extention to clarify where the problem persists.
HTH,
Vasil
06-28-2011 01:04 PM
Hi Partha,
Just to add a quick note to the good tips from Java and Vasil (+5 guys! )
Don't forget to check the DN/Line page itself for any CSS/Partition anomalies.
Cheers!
Rob
