10-17-2007 01:51 PM - edited 03-15-2019 12:00 AM
We had an issue that some users where experiencing intermittend fast busy
i ran a debug and saw this message. I suspect that some channels where out of service.... any one seen this?
Change Status i = 0xC1 - maintenance
Called Party Number i = 0xA1,
'XXXXXXX'
Plan:ISDN, Type:National
1019214: Oct 17 09:02:55 PDT: ISDN Se4/0/1:23 Q931: TX -> DISCONNECT pd = 8 cal
lref = 0x074D
Cause i = 0x8090 - Normal call clearing
1019215: Oct 17 09:02:55 PDT: ISDN Se4/0:23 Q931: RX <- SERVICE pd = 3 callref
= 0x00
Channel ID i = 0xE9808397
Exclusive, Interface 0, Channel 23
1019216: Oct 17 09:02:55 PDT: ISDN Se4/0:23 Q931: RX <- CALL_PROC pd = 8 callre
10-17-2007 01:58 PM
what do you get when you do a sh isdn service?
10-18-2007 06:40 AM
what does that command show?
10-18-2007 06:55 AM
It shows the current channel status and state.
The first row tells you if a channel is in use or idle
The second row tells you which channels are in service or out of service
10-17-2007 02:00 PM
Yes, some part of the debug is missing but it seems so. Ask telco if they are aware of that.
If you are connected to a dms-100 switch, you can also ask that service messages are not to be sent.
