understanding isdn message
jgittins1
We had an issue that some users where experiencing intermittend fast busy
i ran a debug and saw this message. I suspect that some channels where out of service.... any one seen this?
Change Status i = 0xC1 - maintenance
Called Party Number i = 0xA1,
'XXXXXXX'
Plan:ISDN, Type:National
1019214: Oct 17 09:02:55 PDT: ISDN Se4/0/1:23 Q931: TX -> DISCONNECT pd = 8 cal
lref = 0x074D
Cause i = 0x8090 - Normal call clearing
1019215: Oct 17 09:02:55 PDT: ISDN Se4/0:23 Q931: RX <- SERVICE pd = 3 callref
= 0x00
Channel ID i = 0xE9808397
Exclusive, Interface 0, Channel 23
1019216: Oct 17 09:02:55 PDT: ISDN Se4/0:23 Q931: RX <- CALL_PROC pd = 8 callre
bgibson
what do you get when you do a sh isdn service?
what does that command show?
It shows the current channel status and state.
The first row tells you if a channel is in use or idle
The second row tells you which channels are in service or out of service
paolo bevilacqua
Yes, some part of the debug is missing but it seems so. Ask telco if they are aware of that.
If you are connected to a dms-100 switch, you can also ask that service messages are not to be sent.
