02-10-2017 11:41 PM - edited 03-17-2019 09:29 AM
Hello Guys,
One of our customers has been looking for ordering new licenses. I am assisting a colleague to locate the SKU for the licenses they want to order. I was not able to locate a link on Cisco site where I can find this information. request your help to point me in the right direction so I can locate the SKU to be purchased by the team for the Unified communications, the information I have is as below all for version 10 and they need to purchase similar licenses hence I was looking for the relevant part number information.
CUWL Standard
Enhanced Plus
Enhanced
Basic
Essential
CUWL Standard Messaging
Basic Messaging
SpeechConnect Port
Alok
02-11-2017 01:02 AM
Hi Alok,
you need to login into CCW.
The Top level Part Code would be
R-UCL-UCM-LIC-K9
followed by CUCM-VERS-10.X, LIC-CUCM-10X-ENH
regds,
aman
02-12-2017 01:00 AM
Hi Aman,
Thanks for your reply, I was able to locate to top level SKU that you mentioned above. For the other types that I mentioned in my earlier post like the Enhanced , Essential, Basic. Do I need to search them separately or they are all tied under the Top Level SKU?
I tried to filter the others but not sure if they have a separate SKU or are included under the top level SKU?
Alok
02-12-2017 07:10 AM
02-13-2017 04:10 PM
Hi Aman,
Thanks for your help. I am currently unable to view this file. Will go through it later.
Alok
03-26-2018 04:46 PM
Hello Aman,
R-UCL-UCM-LIC-K9 is no longer allowing me to select 10.x Enhanced Plus as an option.
Is there a new top-level SKU?
10-31-2017 03:51 AM
06-22-2018 08:01 AM
Hi!
Here's top-level SKU for CUWL and Unity Connection Licenses:
CUWL-11X-K9
UNITYCN11-K9
