Unified communications License SKU
a.pednekar
Hello Guys,
One of our customers has been looking for ordering new licenses. I am assisting a colleague to locate the SKU for the licenses they want to order. I was not able to locate a link on Cisco site where I can find this information. request your help to point me in the right direction so I can locate the SKU to be purchased by the team for the Unified communications, the information I have is as below all for version 10 and they need to purchase similar licenses hence I was looking for the relevant part number information.
CUWL Standard
Enhanced Plus
Enhanced
Basic
Essential
CUWL Standard Messaging
Basic Messaging
SpeechConnect Port
Alok
8 Replies 8
Aman Soi
Hi Alok,
you need to login into CCW.
The Top level Part Code would be
R-UCL-UCM-LIC-K9
followed by CUCM-VERS-10.X,  LIC-CUCM-10X-ENH
regds,
aman
Hi Aman,
Thanks for your reply, I was able to locate to top level SKU that you mentioned above. For the other types that I mentioned in my earlier post like the Enhanced , Essential, Basic. Do I need to search them separately or they are all tied under the Top Level SKU?
I tried to filter the others but not sure if they have a separate SKU or are included under the top level SKU?
Alok
Hi Alok,
You can refer the attachment which would help.
you need to select R-UCL-UCM-LIC-K9 which is main part code under which u add CUCM S/W version and desired licenses.
regds,
aman
Hi Aman,
Thanks for your help.  I am currently unable to view this file. Will go through it later.
Alok
Hello Aman,
R-UCL-UCM-LIC-K9 is no longer allowing me to select 10.x Enhanced Plus as an option.
Is there a new top-level SKU?
But how will we order CUWl license with above mentioned part code.. is there any guide to help us how to order the licenses exactly?
eva29
Hi!
Here's top-level SKU for CUWL and Unity Connection Licenses:
CUWL-11X-K9
UNITYCN11-K9
Itumeleng
Hello!
Does below Sku's license the CUCM
A-FLEX-NUPL-E
A-FLEX-NUPL-A
