unity_4.x, DUCS and lotus_notes - question, need advice
ReadersUK
Level 2
Level 2
I have a Unity server intergrated with lotus notes. The issue i have is that there is more than one notes server and my unity box can only see one server so i can not add any users on my 2nd notes server. Can Unity be configured to work with more than one notes server?
Colin
jehlas
Hi Colin,
As per: http://cisco.biz/en/US/docs/voice_ip_comm/unity/404/installation/guide/dom/IG_018.html#wp1685778
"Step 4 On each Domino server that will home Cisco Unity subscribers, install csServer, the server component of DUC for Cisco."
I would ensure that the DUC has been installed on each and every Domino server that hosts users you want to add to Unity.
Hope this helps,
John
Hi John
Thanks for your reply. It didnt fix my problem but i appreciate you taking the time to respond.
regards
colin
