Unity Admin Page Error "Unable to access the audio stream on the voice server"
Zafar Ullah
Hi Guys
I am having problem with  Unity server admin page.when click on Subscribers page it gave me Error message saying
Have any one come across this issue if yes how did you resolve it.Your help will be much aprreciated.
I have also attached the Error message Image
8 Replies 8
Chris Deren
Hi Chris
Yes I have gone through this document but with no luck
Zafar
Hi Chris
Thanks for your reply.I have already Gone through these discussion but still have not able to resolve it
Rob Huffman
Hi Zafar,
Can you please provide your Unity version.
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
Hi Rob
Below is the version of Unity
Cisco Unity 8.0 Build 8.0 (3.3)
Zafar
Guys any idea ???????????
I had a similar error with the Media Master Java applet on Unity Connection 8.6. It turned out to be the JRE version (Java 7 update 9) running on my PC. I downgraded back to Java 6 update 36 and it started working again.
Since you're running traditional Unity you may want to try this from the Unity server. If it works there you know it's a client-side issue. If it doesn't work on the server either it's time to open a TAC SR.
Please remember to rate helpful responses and identify helpful or correct answers.
