Unity and Active Directory integration
twissam
i have a scenario where unity was installed and integrates with corporate AD. Now this server does not exist any more and i need to clean the AD from the attributes added by Unity.
any one knows a way of doing so!!
Good day
kelvin.blair
Level 5
Level 5
Unity uses Exchange. You need to follow the microsoft instructions on removing an Exchange manually from AD. It will require you to run ADSIEDIT.
Here is the link...
http://support.microsoft.com/kb/260378
mchandak
Level 7
Level 7
When you extend the schema for Unity, the attributes added are listed under Table 5 and 6 at http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/whitpapr/datadir.htm#wp1095387
You can remove the values set for this attributes for all Unity subscribers. You cannot delete the fields as a limition with AD is that any changes to the schema cannot be removed.
