i wannt to integate the cisco callmanager express 4.0 with microsoft exchange 2003 . the aim to see the MS calender or MS task or both and navigate it from Cisco ip phone
No errors in the logging!The packets are discarded because of unknown or unsupported protocols?Anybody familiar with this error?
HiI have connected vg248 across wan and tried to register it with CCM. I have enabled the DHCP option on VG248 and could not get the ip address assigned to it. I have other phones on the same subnet and they could register and get DN. IP help-address...
I am trying to configure secure SRST and am having a problem. How do you get the certificate to the SRST router? I am trying to add the SRST Reference in CM, and am getting a message saying no connection could be made because the target machine refus...
When upgrading from 3.3(2) is it required to have the Private Password Phrase entered during the upgrade process.Does this need to be entered once on the Publisher and then the same password entered when upgrading the Subscriber or will the upgrade f...
I have a need to find out how a Cisco Phone could register to a CallManager accross the Internet by going through a VPN device like a PIX at the hub where the callmanager sits. So the phone would not have a VPN device at the remote site it would just...
Hello,We're using CME 4.0(3) on IOS 12.4(4)XC6.We're not able to transfer or park calls with other numbers INSIDE our dep. The transfer to outside numbers works regularly.When we try to transfer or park calls, the active call is put on waiting (pause...
Hi,I have a CallManager Express 3.3 and some Nokia E61 phones. I don?t know how configure this phone in callmanager express and there is not any documentation in cisco web side. Thanks a lot for your help.Best regards
Hi,I have installed ccme 3.3 for one our customer.Now the requirement is as followsThey have two analong numbers with 4 line in each.so each number belongs to a specific department.now they want each department to use the number assigned to the depar...
Gents ,Can anyone help/advice me to install CCM 4.0?
Is there "Call Presence" on Cisco CallManager 4.1(3) or 4.2 ? So for example, if the Operator Calls the users, he would know if the user is busy or not, and I still want to keep that each Line can have two lines.Thanks
Hi, Does anyone have any better ideas but do I really need to create an ephone-dn for each E1 channel on an overlay key if I want a broadcast hunt group on a E1 DDI?
Hi All,Is there anyone who can help me to retrieve my incoming and outgoing calls for a particular date using call manager administration or any other third party software?..Thank you very much in advance,Best Regards,Lester
Here's the scenario.A call comes in from the PSTN (site 1). The Call is set to forward to a user across the WAN to another CME System (using PLAR for example, to site 2). The Person picks up the phone (site 2) and transfers the call to another IP pho...
dear sir, Please help, anyone have any idea with the title mentioned? thanks.
Subject | Author | Posted |
02-10-2025 04:39 AM | ||
02-07-2025 02:45 AM | ||
02-04-2025 01:17 PM | ||
02-04-2025 06:55 AM | ||
02-04-2025 01:31 AM |
User | Count |
3 | |
2 | |
2 | |
1 | |
1 |
