Unity and Unity connection in parallel
tim.stapleford
I currently have Unity ver 5 in production environment and am migrating gradually to connection ver 8,5, I have the 2 connection servers built and licensed on VMware ready to go.
Can anyone see an issue with adding the connection servers to callmanager with different Partition/css and device pool/voice ports etc to the Unity servers and run them side by side, I can then phase in connection at my leisure.
Any advice would be appreciated.
Thanks Tim
barry
Level 7
Level 7
Hi Tim
Can't see any issues with this.
As an alternative if you want to keep things simple, you could just add the new Connection server as a second voicemail integration (using it's own VM ports, extension numbers on CUCM etc). You could then create a 2nd VM profile on CUCM and assign users to that as you wanted to migrate them over. Simpler than creating new CSS/partitions IMHO.
Barry
Thans for the speedy response Barry, thats what I had in mind, just wanted a confidence check before I push on.
No problems Tim; best of luck.
Barry
