06-13-2018 12:25 PM - edited 03-17-2019 01:00 PM
I have an application within UCCX. The users want to be able to enable an alternate greeting for days were staffing is limited. I am going to move this initial prompt to Unity and set them as call handler owners so they can enable the alternate greeting before the call hits UCCX. I see standard, holiday, closed, internal, error, busy and alternate. I have a schedule set from 8AM-12PM / 1PM-4PM so I can use the standard and closed greetings. I need to enable a separate greeting from 12PM-1PM for "Lunch" How would I go about doing this?
Also is there a way to play a call handler and then transfer to an extension? The only options I can find are play greeting and transfer to another call handler then within this call handler I could setup the transfer and skip greeting. Is this best practices for something like this? It seems like a waste to have an additional call handler just for the purposes of transferring after the initial standard greeting.
Solved! Go to Solution.
06-13-2018 01:18 PM
To transfer to an extension after a call handler plays, you need to create a new call handler and change the transfer rules to the extension you need to send it to.
So it will go something like this:
Main number > Call Handler_Main_Greeting> Call handler-forward-to-extension.
You'll have to set the after greeting action on the Main_Greeting CH for all greetings that you'll use (Alternate/Standard/Closed) to point to the Call handler-forward-to-extension CH, then set the correct extension in the appropriate transfer rule on the Call handler-forward-to-extension (Edit>Transfer Rules)
Unless you want to get really complicated, your lunch hour time would be seen as "closed" by UC... If you want a little bit more usability with scheduling and such, I would think that UCCX would be able to handle it a lot better.
06-14-2018 07:28 AM
You're transferring the calls the way CUC allows it, yes it does seem kinda clunky to have to create a call handler just for the purpose of the transfer, but that's the way to do it
06-13-2018 01:18 PM
06-14-2018 07:28 AM
06-14-2018 07:48 AM
