- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-13-2018 09:32 PM - edited 03-17-2019 01:00 PM
Well, halfway. We're switching from SCCP to SIP so was switching a phone. It gets an ip address, gets halfway through downloading files. But it just stops after apps42.9-4-2ES26.sbn, repeats the process, then reboots and the whole things starts over again.
1049345: Jun 13 20:14:38.822: TFTP: Looking for term62.default.loads
1049346: Jun 13 20:14:38.826: TFTP: Opened flash0:phone/7942-7962/term62.default.loads, fd 4, size 666 for process 135
1049347: Jun 13 20:14:38.838: TFTP: Finished flash0:phone/7942-7962/term62.default.loads, time 00:00:00 for process 135
1049348: Jun 13 20:14:39.722: TFTP: Looking for jar42sip.9-4-2ES26.sbn
1049349: Jun 13 20:14:39.726: TFTP: Opened flash0:phone/7942-7962/jar42sip.9-4-2ES26.sbn, fd 4, size 1765313 for process 135
1049350: Jun 13 20:14:46.670: TFTP: Finished flash0:phone/7942-7962/jar42sip.9-4-2ES26.sbn, time 00:00:06 for process 135
1049351: Jun 13 20:14:52.046: TFTP: Looking for cnu42.9-4-2ES26.sbn
1049352: Jun 13 20:14:52.046: TFTP: Opened flash0:phone/7942-7962/cnu42.9-4-2ES26.sbn, fd 4, size 581755 for process 135
1049355: Jun 13 20:14:54.430: TFTP: Finished flash0:phone/7942-7962/cnu42.9-4-2ES26.sbn, time 00:00:02 for process 135
1049356: Jun 13 20:14:56.966: TFTP: Looking for apps42.9-4-2ES26.sbn
1049357: Jun 13 20:14:56.966: TFTP: Opened flash0:phone/7942-7962/apps42.9-4-2ES26.sbn, fd 4, size 4638412 for process 135
1049358: Jun 13 20:15:15.258: TFTP: Finished flash0:phone/7942-7962/apps42.9-4-2ES26.sbn, time 00:00:18 for process 135
And that's it. term62.default shows dsp42.9-4-2ES26.sbn should be next. Did a couple of factory defaults on the phone without luck. Any ideas what I should look for in why it's stopping here?
Thanks!
Solved! Go to Solution.
- Labels:
Other IP Telephony
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-14-2018 05:04 AM
Hi @Chojin
Do you re try to xtract again the archive firmware tar file?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-13-2018 10:27 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-14-2018 07:34 AM
The phone was 9-4-2 SSCP before. I'm switching it to 9-4-2 SIP. There was no problem upgrading the phone to a newer SCCP firmware. So I'm assuming the hardware version can handle 9-4-2. I'll try re downloading the firmware then uploading fresh to the router.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-14-2018 05:04 AM
Hi @Chojin
