09-10-2015 12:02 PM - edited 03-17-2019 04:16 AM
I'm considering changing the IP address of our current CUCM publisher. If I do go through with it, what changes in Unity would need to be made. I've been searching for any documentation on this specific issue, but have come up short.
Solved! Go to Solution.
09-10-2015 07:27 PM
Once you re-IP-ed the cucm, go to your unity server:
Telephony Integration>Port Group>Edit>Servers and put in the new IP address of the CUCM
09-10-2015 12:45 PM
Depends on what integration you have, you can review the SIP/SCCP integrations docs and they will mention where you use the IP/hostname/FQDN of the servers, and you only need to go there and update with the new info.
09-10-2015 07:27 PM
