unity connection 7.x error message connecting with cobra export
boub91
Unity connection 7.x
cobra tool export
unable to connect to unity connection 7 database using cobra tool export.
-informix has been installed
-user right for remote has beendeclared
-proxy database is started
when we trying to connect to unity connection with cobra we have the folloing error message :
Error in load routineError opening event source registry key - access is denied - 2147024891
Rob Huffman
Hi Alain,
Have a look at this thread where the person was getting this
same error while trying to run Cobras;
https://supportforums.cisco.com/message/1216469#1216469
Hope this helps!
Rob
Hi Rob,
Thank you for your reply I will check this issue.
I tried with windows XP and it's working fine.
Thank you
