unity connection 8.0 in cluster
shohamshalom
hello
i configure unity connection in cluster and did all the steps that cisco sagest.
on cucm manager 8.03  i build voice port that sinc only with the UNITY-PUB.
when i test the cluster performance i shutdown the UNITY-PUB and the voice port unregister
so maybe i need to build more voice port that will sinc with the UNITY-SUB  in this case?
cisco pdf not mantion it
TK
Rob Huffman
Hi TK,
Yes, ports need to be built/assigned to both the Pub and Sub
in a Unity Connection cluster
Here's an example;
Voice Messaging Port Configuration for a Connection Cluster
For a Cisco Unity Connection cluster, you must know how the voice messaging ports will function—which ports will answer calls and which ports will dial out (for setting MWIs and for sending message notifications). Depending on the function of the ports, you will assign them to the applicable server in the Connection cluster:
Answering ports
Beginning with the answering port that has the lowest number in its display name, assign half the answering ports to the subscriber server so that the subscriber server will answer most incoming calls. Assign the remaining answering ports to the publisher server.
Dial-out ports
(for MWIs and notifications)
Beginning with the dial-out port that has the lowest number in its display name, assign half the dial-out ports to the primary server so that the primary server will handle MWIs and notification calls. Assign the remaining dial-out ports to the subscriber server.
For example, an eight-port system with six answering ports and two dial-out ports can be configured as follows.
Port Function
Port Display Name
Server
Answering
UCM1-001
Subscriber
UCM1-002
Subscriber
UCM1-003
Subscriber
UCM1-004
Publisher
UCM1-005
Publisher
UCM1-006
Publisher
Dialing out
UCM1-007
Publisher
UCM1-008
Subscriber
Under normal conditions, the Cisco Unity Connection cluster will handle calls in the following manner:
The subscriber server will answer most incoming calls. If no answering ports on the subscriber server are available, the publisher server will answer calls.
The publisher server will dial out for MWIs and notifications If no dial-out ports on the publisher server are available, the subscriber server will dial out for MWIs and notifications.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/integration/guide/cucm_sccp/cucintcucmskinny200.html#wp1073447
Cheers!
Rob
