IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5422 Views
  • 14 replies
Hello Freinds,i need help to get our setup for mobile access working from internal extentions, we are able to get the call flow working from outside call,when call came from PSTN to extention configured for snr we are able to get the call on both, ex...
I need to export all of the phones from a 7.1.3su2 cluster to an 8.0.3 cluster. All system device pools, regions, profiles, PT, CSS etc. are all the exact same.I have attempted an 'all details' phone export and then all details import, but it appears...
jburk by Level 1
  • 497 Views
  • 3 replies
Hi all,I have two BRI Lines on a CCME.1-BRI 0/2/02- BRI 0/3/0I have an extension 0036, if any body make International kal from 0036 extension, the call should be route through BRI-0/3/0 ...If any body make international call from any other extension ...
Hi community,I have a lab for preparing ccie voice including CUCM 7.0 running on MCS 7845 server. My problem is when i open phone config page to configure phone devices it takes  too long to load  the page  i have to wait almost 4-5 minutes. it is sa...
I have a Cisco 2911 Voice bundle w/SRST and 4FXO ports. We are currently using the FXO trunks for outside calling (off net) to the PSTN.We are growing and I need to add more lines. I want to move to a full PRI and drop the FXO trunks.Which card do I ...
Hi,I have a CUCM 8 and a GW 2811 and I want to know how do I change the calling number.For example, my trunk number is 31325160 and my directory is 9061 if I call someone in PSTN I want to show the calling number as 31329061 not 31325160.How can I do...
Hi,I am looking for voip encryption solution, Cisco Canada(Montreal) said that this solution has never been deployed, at least in Canada.I can't believe that Cisco secure voip is not deployed in our government institutions which means that any networ...
omahrez by Level 1
  • 491 Views
  • 1 replies
