Unity Connection 8.5 - mailbox size per user
Not applicable
Hello
I am wondering if there is some way to find out how much space subscriber mailboxes are taking up on the server?  I can see total space utilization for the mailstore, but I would like to find out how much space is being used by our subscribers.  Access to this information would help me set realistic mailbox size quotas and create a sensible aging policy... thanks!
Gajanan Pande
You can use the 'UserDataDump' utility to accomplish individual User mailbox size.
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/UserDataDump.html
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/Help/UserDataDump.htm
Another CLI command you can try is:
run cuc dbquery unitymbxdb1  select skip 0 first 100
description,bytesize FROM vw_mailbox order by bytesize desc
Pls remember to rate helpful posts, always.
GP.
Hello Gajanan
Thank for your help so far.  I am not very familiar with the CLI - can this, or a similiar query be used in CUDLI instead and would you be able to provide me with another example?
Thank you!
el
Am not familiar with CUDLI, sorry mate.
GP.
