Bookmark
Subscribe
4465
Unity Connection 8.5 single inbox with exchange 2010 - errors
kwaldecker
Hello All,
I am doing a unity connection 8.5 install.  They are wanting the single inbox tie in with exchange 2010.  I have gone through all the docs for the install and have configured the unity connection server and exchange 2010 according to the cisco docs.
When i run the test on the Unified Messaging Service it all comes back fine.
However when i run the messaging test under the user it fails and gives me the following error:
issue:
Failed accessing williac6@gcsnc.com on outlook.gcsnc.net
Recommendation:
Some possible reasons for 401: Incorrect service account name or password. Service account password expired. Proper permissions not granted to service account. Exchange mailbox uninitialized.
So when i leave a voicemail it does not go in the mailbox.
Anyone seen this message before or how to fix it?
7 Replies 7
I've been fighting with this issue and finally found a resolution.
I used the Microsoft tool EWS Editor (http://archive.msdn.microsoft.com/ewseditor) to test the configuration on the Exchange server.  Use the URL "https://<servername>/EWS/Exchange.ASMX". Use the server name that is referenced by the server certificate you loaded on the Unity box.  You can input the Unity Server Account and test the impersonation function to access a users mailbox.  This tool will verify the permission setting of the Unity service account.
The big issue that I ran into was the test functionality within Unity.  I had the incorrect password for the Unity service account.  When I used the configuration of Forms Based Authentication within Exchange, Digest Authentication on Unity and the incorrect password, Unity reported that it was able to access the user mailboxes.  This is a FALSE POSITIVE!!  We disabled Forms Based Authentication on Exchange, change to NTLM authentication on Unity and corrected the password used.  This corrected the issue.
Please keep in mind that Single Inbox on 8.5 to Exchange 2010 is new and TAC has a very small toolbox to troubleshoot issues.
Chris
thanks Chris,
I just passed this along to their exchange team.  They are looking at the program now to see how it works.
In your response below you mention loading a certificate on unity connection.  Am i missing a step?   i don't recall doing that during the setup
If you will be using SSL, you will need to upload the correct Exchange cert to the Unity server.  Please reference the link below.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/unified_messaging/guide/85xcucumg020.html#wp1198072
ahh thats why i didn't see it.  not using ssl here.
thanks! waiting to hear back from their exchange group to see if they fixed the issue
Please reach out to me if I can help in the future.
Nelson Alonso
Hey Chris. Running into the same issue here with the 401 error message when I test the account. We followed the steps all the way. Any idea what fixed it on your end?
Though am late to answer , whoever run in to the same issue may use the below resolution .
Very simple . reset the password of the Unity Service account and use a password which does not have any special charecters !!!.. It'll work . It just worked for me
Best Regards
Rajesh
