Unity Connection 9.1
Brian Houston
I've successfully installed a Unity Connection 9.0 cluster on UCS C220-MS3 platforms and subsequently upgraded it to 9.1.
I created a port group and I'm trying to add 48 ports to that port group. When I do this I get the following message:
"Port limit reached to its maximum allowed configuration for its hardware "
Instead of creating 48 ports, only 8 are created.
IN creating the virtual machine for Unity Connection, I deployed OVA template CUC_9.1_vmv8_v1.5.ova and in doing so selected the 1000 user option. From what I can see in the OVA spec, this should support 48 ports in an Active/Active configuration.
Any ideas as to what is going on here?
21 Replies 21
Thanks Baris (+5)
I installed the ciscocm.cuc_license_patch.sgn and now its OK,
But my CUC Version is not on the affected versions: 9.1.1.20000-32, i asked the author of the post to see this.
Thanks again
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Hi Leonardo,
Version 9.1.1.20000-5 and 9.1.1.20000-32 is same .
9.1.1.20000-5 is the Platform version and 9.1.1.20000-32 is Unity specific .
You can see from the following commands ...
admin:show version active
Active Master Version: 9.1.1.20000-5
admin:show cuc version
Active version: 9.1.1.20000-32
I had the same issue but solved it with a TAC and the engineer fixed via SQL commands. Just log a TAC and the can help you out.
Hi Brian,
Also I had a same problem during the installation of localization file. Did you get any TAC solution ?
Baris.
This patch works !
Another co-worker found another solution :
Shutdown the VM
Upgrade hardware (RAM and vCPU)
Restart and check/renew ports
And if it's good, shutdown the VM, downgrade hardware, restart VM.
Sebastien
Hi Sebastien,
This method of upgrading vCPU is not supported and should not be used .
Applying the COP file or upgrading to a latest ES are only supported solutions
antonio.vazquez
I have experimented this in 10.0.
Is there any solution?
Note: We have upgraded from 9.1 and we have tried to add more ports.
