Unity Connection AA for Transferring Directly to VM
SCOTT TURNER
Is there any way to create an auto attendant in Unity Connection that transfers the caller directly to voicemail instead of transferring to the extension?  I've been banging my head against the wall trying to get this to work.
Scott
Jaime Valencia
That's not determined in the call handler, that's determined under the transfer settings of EACH subscriber.
You can only choose one (ring phone or get the greeting), so there's no way to have both behaviors in CUC.
Only way I could see this work would be by adding a suffix to the DN, sending the call back to CUCM, then hitting a TP to strip the suffix and add * so you can use the method for sending someone directly to VM from CUCM.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Java,
Thanks for your reply.  Interesting point about the user mailbox making the transfer descision.  I used to work a lot on Octel Aria platforms, which had menu + mailbox AAs.  I was trying to simulate that in Unity, but may have to use the transfer to CUCM method like you suggested.
Thanks!
Scott
