Unity Connection Administration Password requires CLI reset after every reboot
RAustin70
I have had to restart one of our two 11.5 CUC cluster servers twice in the past 6 months due to power/environmental issues.  Both times, It comes right up, BUT the Administration account password no longer works on either server, and I end up going into the CLI to set the password.
Quick Google & Community Search doesn't show anything, has anyone else had this problem?  Is this TAC worthy?
Jaime Valencia
I'm running 11.5.1.14900-11 and I haven't seen that issue, had previous SUs and also didn't see the issue, might want to open a TAC so they can find out what is causing that in your specific environment.
java
if this helps, please rate
Yeah, it JUST did it do me again, and I didn't reboot.  and that jogged a memory loose that the same thing happened last time, had to go CLI and change it like 3 times.  running Version 11.5.1.11900-26
