unity connection bulk update greeting
Kosi227
Hi All,
i am currently using CUC9.1.2, and reg with 270 users.
And right now we are plan to update  their greeting to standard company greeting for everyone. is any way that i can bulk admin to do it instead to config it one by one.
thanks alot
simon
Accept what was and what is, and you’ll have more positive energy to pursue what will be.
Chris Deren
You should be able to select the users, press the bulk edit button, then go under edit --> greeting --> select standard recording --> check the checkbox next to greetings and use the play/record applet to upload your greeting or record it.
HTH,
Chris
Chris Deren
HTH,
Chris
Thank You Very Much!
