Unity connection call handler
caseywyman
I have Unity Connection 10.5 and CUCM 10.5 and I am trying to setup a Call Handler to transfer to an outside number after caller input is detected. I have read around and made several changes but it has not fixed my issue. I have removed all restrictions from the table and have allowed transfers to numbers not associated with users or call handlers.
I have an extension setup that is forwarding to a 1800 number and it forwards fine. I can call the call handler from an internal phone and press 1 and it transfers to the 1800 number. When I call from an outside line and press 1 I get the "please hold while i transfer your call" message and then the phone just hangs up within 10 seconds. I am a bit confused on why this will work internally but not externally. Any help would be appreciated.
Chris Deren
Are you using Local Route Groups? If so, ensure the device pool assigned to your Unity SIP trunk or voicemail ports (depending on what integration method you are using) has proper LRG assigned.
Brandon Pierce
Level 4
Level 4
What route is the call taking once it hits your CUCM?  You will need to see how it comes in, and then trace it from there as well.
Chris Deren
Thanks for the help. I was deploying the 2nd remote site on this CUCM and the SIP trunk was setup to use the local route group of the 1st site that was setup.
Anas Abueideh
Level 9
Level 9
is your 1800 numbers offnet or onnet calls ? if it is offnet calls, you might need to disable block offnet to offnet parameter and make it false.
Anas
don't forget to rate the helpful posts
