11-26-2014 03:49 PM - edited 03-17-2019 01:07 AM
Hi everyone,
So I am stuck in a typical Cisco-Java comic situation trying to get a simple CNX upload of a prompt audio file.
I can spin any version of JRE and any version of IE or whatever browser could possibly make this work. I assume this must have worked once upon a time since Cisco sold number Unity Connection 8.6.1.20000-109 at some point.
The issue is with the play/record java applet when doing prompts. It comes up with SSL error but which SSL? Obviously the CNX certificate is trusted; no IE "press to continue" errors and the JRE crap is figured out to make the applet load in the first place but once you open a file and click SAVE the following error pops up:
I am stumped at this? OK of course doesn't fix it. As I said otherwise the applet loads just fine with no detectable error issues:
I would appreciate feedback if there is a remedy to this situation.
Thank you!
12-01-2014 01:52 AM
Have you tried adding the CUC server website to the 'trusted' sites in the Java control panel?
Make sure you add it with the correct http/https prefix etc as well.
Aaron
01-28-2015 03:57 PM
Thanks Aaron
Yes I have; and to be clear I added the certificate NOT under the browser but inside the control panel; then Java's own security thing where you get to add certificates.
That did not help! I did make sure it is https AND it is the correct port as it isn't the standard SSL port
Still no go!
