Unity Connection Direct Transfer to Voicemail for E.164+ Extensions
James Hawkins
Level 8
Level 8
I have set up CUCM 9.1(2) and Unity Connection 9.1(2) with an E.164+ based dialplan for all users.
I want to set up direct transfers to email using * as a leading digit but this does not seem to work with the E.164 numbers.
I have followed the standard method as described at the link below but am getting no success.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/26862-transfer-voicemail.html
The issue seems to be that the + sign cannot be preceded by * in a valid CUCM dial string and still work.
I cannot use alternate extensions as the functionality is required for Attendant Console which sees the full E.164+ formatted DN from the CUCM directory.
Any ideas how to solve this?
15 Replies 15
lukeksmith
Level 4
Level 4
I was able to get this working on CUCM 12 and CUC 12 with an existing partition, new translation pattern, new CTI route point, new directory number, and a new voicemail profile
partition: Site1Intra
Contains translation pattern to transform site-specific abbreviated (4-digit) intra-site dialing to +E164
translation pattern: *3XXX
called party transform mask: *12162533XXX
prefix digits: +
The CTI Route Point contains a DN \+*12162533XXX that will match the transformed digits
The DN is set to forward-all to VM using the new VM Profile
The new voice mail profile uses your existing pilot, but uses this mask +12162533XXX
  • Results Summary
    • Calling Party Information
      • Calling Party= +12162533920
      • Partition= DN:Directory URI:URI:ESN:onNetRemote:Site1Intra:USToE164:USPSTNNational:PSTNInternational:B2B_URI:USEmergency
      • Device CSS=
      • Line CSS= Site1International
      • AAR Group Name=
      • AAR CSS=
    • Dialed Digits= *3945
    • Match Result= RouteThisPattern
    • Matched Pattern Information
      • Pattern= +*12162533XXX
      • Partition= DN
      • Time Schedule=
    • Called Party Number= +*12162533945
    • Time Zone= Etc/GMT
    • Call Classification= OnNet
    • InterDigit Timeout= NO
    • Device Override= Disabled
    • Outside Dial Tone= NO
  • Call Flow
    • TranslationPattern:Pattern= *3XXX
      • Partition= Site1Intra
      • Positional Match List= +*12162533945
      • Calling Party Number= +12162533920
      • PreTransform Calling Party Number= +12162533920
      • PreTransform Called Party Number= *3945
      • Calling Party Transformations
        • External Phone Number Mask= NO
        • Calling Party Mask=
        • Prefix=
        • CallingLineId Presentation= Default
        • CallingName Presentation= Default
      • ConnectedParty Transformations
        • ConnectedLineId Presentation= Default
        • ConnectedName Presentation= Default
      • Called Party Transformations
        • Called Party Mask= *12162533XXX
        • Discard Digits Instruction= None
        • Prefix= +
        • Called Number= +*12162533945
      • Directory Number:DN= \+*12162533XXX
        • Partition= DN
        • TypeCFACSSPolicy= Use System Default
        • Call Classification= Unknown
        • Forwarding Information
          • Forward AllDN = VoiceMail = Yes VoiceMailBoxNumber = \+*12162533XXX CSS = VoiceMail
          • Forward Busy
            • InternalDN = VoiceMail = No CSS =
            • ExternalDN = VoiceMail = No CSS =
          • Forward No Answer
          • Forward No Coverage
          • Forward Unregistered
          • CFDFDN = VoiceMail = No CSS =
          • Pickup Group Number=
        • Device:Type= CTI Route Point
          • Device Status= UnKnown
          • Device Name= TransferToVM
          • Ignore Presentation Indicators= Disabled
          • Logged Into Hunt Groups= Enabled
          • Alerting Name=
          • Dual Mode= Disabled
          • Automated Alternate Routing (AAR)
            • AAR Group Name=
            • AAR Calling Search Space=
            • AAR VoiceMail Status= Disabled
            • AAR Destination Mask=
            • AAR Prefix Digits=
          • Alternate Matches
            • Note: Information Not Available
