IP Telephony and Phones
Labels
I have attached a screenshot of Cisco RTMT that shows the calls.  We receive calls that are labelled as "911", however, there is no answer.  More than likely it's a spoofed call, however, has anyone else run into this and if so, how did you remedy th...
plavin001 by Level 1
  • 647 Views
  • 2 replies
Hi!   I'm upgrading a UC environment from 11.0 to 11.5. One of the pre-upgrade tasks is to ensure the subnet mask is in the recommended format for /24.   "If you are using a 24-bit IP subnet mask, ensure that you use the following format:255.255.255....
Knowlesy14 by Level 1
  • 1612 Views
  • 10 replies
I have set up a SIP trunk from my  3rd party PBX to my IOS 12 voice gateway which in turn forwards calls to CUCM. Calls from phones registered on CUCM are working fine, however calls from PBX to CUCM via the router do not go through. The phone keeps ...
DavidW by Level 1
  • 2581 Views
  • 4 replies
I have three 9971 phones all registered to the same CUCM.  They all have the same firmware and as far as I can see all three have the same settings include video enabled, etc.  However, one of the phones cannot place video calls. The camera is workin...
tato386 by Level 6
  • 2248 Views
  • 7 replies
Good morning,I am attempting to figure out how to use a SBC to rewrite a SIP Invite and extract the Presence Information Data Format PIDF-Location Object (PIDF-LO) and rewrite it in a standard Automatic Location Information (ALI) format.The PIDF-LO i...
tmizzell1 by Level 1
  • 1650 Views
  • 2 replies
Hi all. I have a client who is complaining about a loud crackling noise whenever they try to make a call. The noise stops as soon as the person on the other end answers the call and the actual conversation starts between the two parties. So the probl...
I have a request to find who called 911 from an IP-Phone. I tried dialed number analyzer but it requires a calling party which is what I am looking for. Can anyone assist on how to find the number that called 911.
BigK by Level 1
  • 1650 Views
  • 5 replies
Hi all, I have a CME connecting to SIP ITSP for routing PSTN Calls. When the PSTN caller call the SCCP internal extension and the internal extension do a consult transfer , it is not working. however, blind transfer is working. Consult transfer is wo...
The data sheets all say the 6800 / 7800 / 8800 series phones support SRTP, but I cannot find a way to enable it on the 3PCC models... not in the UI nor via XML. Am I missing something? The administration guide is the most specific thing I've found; t...
Hi all,Recently I witnessed a DHCP flood on a network which was started by a 7942 Phone (firmware v. sccp42.9-3-1). After power-cycling the phone the DHCP Flood stopped and didn't happen again. I am more interested in understanding the log message th...
Alexey Y by Level 1
  • 1054 Views
  • 2 replies
Hi everyone, I've installed a CUCM version 10.5. I've got the warning, that the DNS is unreachable. By running the command: utils diagnose test, I can see that all terms are actually passed.I've restarted the Tomcat services as well. Im working with ...
Ana68 by Level 1
  • 4221 Views
  • 5 replies
