Unity Connection Hardware Matrix
reb-gun3000
can anyone point me to a hardware compatibility Matrix for CUC that lists all the versions?  I want to make sure we upgrade to the highest possible revision support on the servers we have.
Thanks.  Replies rated.
2 Accepted Solutions
James Hawkins
Level 8
Level 8
Unity Connection uses the same underlying operating system as CUCM so the document below which details CUCM compatibility should be good for CUC too.
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
I have used this without any issues in the past but if anyone disagrees please post.
Rob Huffman
Hi there,
I'll just add another reference to the great info from my friend James here (+5)
Cisco Unity Connection 8.x Supported Platforms List
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/supported_platforms/8xcucspl.html
Cisco Unity Connection 9.x Supported Platforms List
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/supported_platforms/9xcucspl.html
Cheers!
Rob
"Clocks go slow in a place of work
Minutes drag and the hours jerk"
-The Clash
James Hawkins
Level 8
Level 8
Rob Huffman
Hi there,
Cheers!
Rob
-The Clash
Thanks to you both!
