05-11-2016 12:25 PM - edited 03-17-2019 06:52 AM
rebuilding Unity 8.6 Publisher onto a VM and the install stalls at the NTP server discovery. I am having network connectivity issues right now. Any way to skip past the NTP just to get the software installed and deal with the network connectivity issues after the app is up?
replies rated
05-11-2016 01:30 PM
I believe this isn't possible to skip NTP reachability to complete installation. If you have trouble reaching out NTP on WAN, try to simulate a NTP on a router in your LAN and make sure unity can reach it. Once the application is up, you can modify NTP server entries.
You need at least one NTP server to complete installation of CUC
Refer: Installation guide of CUC 8.x
Sami
05-12-2016 11:20 PM
Hi Scott,
May be you can try making the ESXi itself as a NTP server.
Try this.
Please rate if helpful.
Adarsh Chauhan
