Unity Connection language whisper facility
jeff.singh
we have a AA on Unity that announces something like press 1 for English, 2 for French, 3 for German. Caller makes their selection and the call is transferred to a multi lingual agent in a hunt group. is there any way that the agent can be notified of the language that was selected by the caller - this way they can answer the call with the correct language - similar to a whisper function on a Contact Centre. TIA..J
Jaime Valencia
Use different hunt pilots for each language, CUC cannot provide any indication of what caller input was used.
java
if this helps, please rate
Ratheesh Kumar
Hi there
Unfortunately not, you best bet is to develop  a CCX script
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
