Unity Connection sip port transfer to phone busy
bo liu
Level 4
Level 4
hello
i user CUCM connection with CUC use SIP
but when i transfer a call to phone from AA ,the CUC say can not transfer the call busy .....
who can tell me where i config is wrong
6 Replies 6
yahsiel2004
Level 7
Level 7
Do you have the correct CSS on the SIP trunk?
Yosh
HTH Regards, Yosh
yes the CSS includ the partition of phone
Did you check the restriction tables on CUC?
Yosh
HTH Regards, Yosh
Can you go to AA call-handler then - edit -transfer rules and choose supervised transfer.
Transfer Type    choose supervie transfer
please rate all useful infomatio
I would also check on the transfer rule for the AA, as islam mentioned (+5)
Yosh
HTH Regards, Yosh
Hi Yosh
Thanks for rating , +5  for your help.
