unity connection transfer
whanson
Level 2
Level 2
When outside caller gets vm and wants to 0 out to operator, I want the call to be transferred to a receptionist number which is not a subscriber. I can't seem to get it to work. If I transfer to a unity subscriber number it works but not to a number that is not a subscriber.
michael.deal
Send the call to a call handler that is set to transfer to the extension.
mike
Mike,
That is what I'm doing. when you 0 it sends to operator call handler which transfers to an extension. If the extension is a defined to unity connect the transfer happens othewise I get operator is not available.
Bill
look at the restrictions tables
java
if this helps, please rate
java
thanks everyone. It turns out the issue is with the integration with NEC via pimg that is the issue not Unity Connection
