Unity Connection upload cert error - unable to generate a hashname
Vinh Nguyen
Hi All
I tried to upload the Exchange Public key to Unity Connection-Trust folder but got the following error.
"Certificate upload failed, unable to generate a hashname"
I convert the certificate from CER to PEM format before I upload.
I upload the same certificate to Tomcat-Trust without an issue
See error in attachment
r.rung
i have the same problem.
after upgrading from 10.5(1) to 10.5(1)SU1 my exchange sync did not work anymore.
after troubleshooting i found out that the Connection-Trust Certificate disapeared.
i am not able to upload it again with the same error.
i got sure that the ca cert is in PEM format.
for me it looks like a bug.
as a workaround you can disable "Validate Certificates for Exchange Servers"
and change
to "LDAP"
