Unity Connection User " 0 Out" Feature
arthurbecker
Where in Unity Connection do you define the "0 Out" feature to all allow callers to transfer to an opeator or another extension without leaving a message?
Rob Huffman
Hey Arthur,
Go to the user and edit "Caller Input" for 0 and send caller to
the desired directory number.
Cheers!
Rob
I believe that is for standard Unity.
This is for Unity Connection 7.x. I have no fields refering to "Caller Imput" under the Users section.....
Hi Arthur,
No, this is from Unity Connection 7.1 which is what we are running as well
If you bring up a User (yourself for example) and then click on Edit> the 7th
selection down from the top of the list should be Caller Input. This is where the Dial 0
would be set.
Cheers!
Rob
Ahhh, thank you Rob! I see that is a drop down under Edit. i never saw this feature before.
   Thanks again, Art
