Unity Express 7 Problems (NME-CME)
Rod.Blackie
HI
We have a Unity Express system which has been configured and working fine since the installaiton. Voicemail number is 5000 and AA is 5001
Last week the voicemail system stopped working - nothing has been changed on the system it just stopped working.
If I dial the 5000 number I get the voicemail systme telling me ' Voicemail system is unavailable try again later. To speak to an operator press 1"
I've reset the NME-CME module, reloaded the router and still get the same message.
Funny thing is the AA is still working ok and I can see the calls coming into the NME-CME when I dial the 5000 and 50001 numbers???
Has anyone got any ideas to help me restore or recover the voicemail system ?
Rod
2 Accepted Solutions
paolo bevilacqua
Hvae you been using a temporary license ? Check "show voicemail mailbox", and  "show license".
7 Replies 7
paolo bevilacqua
Rod.Blackie
Hi P
It looks like it:
Index 0 Feature: VMIVR-VM-MBX >>>>>>>>>>>>>>>>>>is this the licence ??????
        Period left:  0 minute   0 second
        License Type: Evaluation
        License State: Active, Not in Use, EULA accepted
        License Count: 600 / 0
        License Priority: Low
Index 1 Feature: VMIVR-PORT
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: 8 /8
        License Priority: Medium
Although I am sure we purchased a licence in the past - will need to look out the documents
Many thanks
Rod
Now, don't tell anybody, but you can readily obtain a permanent license from the licensing portal.
Thanks for the nice rating and good luck!
Ah you tease !! care to tell me how?
Paolo - You're a star - thanks. I've wasted 2 hours on the licence site trying to obtain a licence many many thanks
Rod
You are very welcome.
I whish more people were to get professional help and go home 5:30 pm instead of banging the head with pointless DIY.
