01-22-2009 08:54 AM - edited 03-15-2019 03:42 PM
I will start the installation for a new telephony ip project that i have those elements :
1- Cisco CallManager 7.0
2- Cisco 2811
3- Unity express in the same router 2811
I want know if the Unity express can be used to receive the voice mail form the CallManager?
Thank you in advance
Hicham
01-22-2009 09:06 AM
Hi Hicham,
Here's a document titled 'CallManager for Cisco Unity Express Configuration Example' that should help you integrate CUCM and Unity Express.
Michael.
01-22-2009 11:56 AM
Hi Hicham,
Yes you can do this. It's referred to as JTAPI integration with CUCM. For CUCM 7 you will want to run the latest CUE 3.2 software. Also, be aware that there is a CUCM license and CME license - get the CUCM license or you'll have troubles.
hth,
nick
